Cleaner 7 wont open setting window
Hi, without asking C cleaner installed Cleaner 7. When i try to open this I just get a welcome screen that doesn’t show any options. i cant close it. i have tried reinstalling it and Cleaner 6 but it is unusable. So much for the latest all singing and dancing version. It doesn’t work. Any Ideas. On Windows 1
We’ve had lots of reports of this welcome screen issue and there’s a work round (it works for most):
Alternatively:
Ok thanks for that. You think the genius IT wonks at cleaner might have seen that one and stuck the close button where the sun shines instead.
