Clean TEMP files better?
I have worked on several pc's (windows 7 mainly) and they are always filled with tons of crap in the "C:\Users\Username\AppData\Local\Temp" folder and ccleaner always misses it. It would be great if the devs could add this to the default settings or tweak CC to clean all the TEMP directories as long as it won't mess anything up in the process..
yes, I agree. :)
have you try it with option --> include? with files and subfolders of this folder?
Yes, I'll have to use that option until something is changed.
winapp2.ini entries are also a good way to extend the cleaning beyond what CCleaner does by default.
Hey guys you're just repeating yourselves from his other thread. He opened this one because "someone" ;) suggested he post in suggestions, so he did.
Some software will create Temp folders and files outside of areas that just aren't the norm or even logical to those of us that like a clean system.
That's why there's the Suggestions forum to easily notify of new areas to clean, that way either Piriform can add them into the default CCleaner setup for everyone to benefit from, or someone will create a winapp2.ini cleaning routine for them.
Other strange areas some software either during setup or when running will create a Temp folder are in:
* %allusersprofile%\Temp
* %userprofile%\Temp
* %Documents%\Temp (aka "%userprofile%\My Documents\Temp", "My Documents/Temp")
I know it's a "continuation/repeat" I don't have Alzheimer yet, and the suggestion to post in this forum area was a general one for anyone reading and wasn't really aimed at just the OP.
:D
I have been wondering why so often the topic was to read lately.
finally once again what German to read, without I have to think about what that means now :lol:
