What is hotfix uninstallers? It's 40mb there I can get ride off, should I clean it with CCleaner? Or just leave it alone?
Thank you!
Thank you!
Thank you!
You can remove them, since it's found to be safe. But if you have a lot of disk space, you can just leave them alone.
They are folders, that contains data to UNinstall installed Microsoft updates.
Okay, thank you
