clean bak from system mechanic
does anyone have easy way to remove C:\Users\greg\AppData\Roaming\iolo\ActiveCareReports\ForSubmit_12312008.xml.bak\ACData is encrypted .
I have uninstalled but keep getting these files showing up on av scan not able to scan. Can not find the folder to delete. SM says to boot in safe mode and do alot of steps I tried and still finding. Hopefully cc can add a easy way to delete files leftover from system mechanic.
thanks.
greg
