Clean another drive than C:
I have plenty datas on my D: like words files etc.
By the way i have plenty of thnings like ~WRL1548.tmp or ~$myfile.doc : very boring
So is there a way to make cccleaner (very good tool !) work on other drives than C: ?
Thanks by advance
Not by default as CC only cleans known temp files on the system drive (which I assume is C). You can of course include files and folders to be cleaned, but CC will wipe the entire folder irrespective of the contents.
Is it possible to use a USB install of CCleaner and have it point to the 2nd or 3rd hard drive of a machine?
