Latest version somehow stopping Adguard (extension) from running properly. It's still enabled but just doesn't work until I manually update filters or reinstall the extension. No problems with previous version (5.15) on the same configuration (Windows 10 x64, Chrome beta 50.0.2661.57 and adguard 2.2.3).
Also, you really should have some section on the website with one or more previuos versions available...
Here's how to find the entry that is removing the ad subscriptions.
Starting with the chrome section, right click an entry (e.g. Cache) choose clean
Open chrome; if broken take note and continue
If not broken continue
Close chrome
Right click the next entry under chrome heading and continue throughout.
If no chrome entries break the adblock you'll have to work each entry in ccleaner in this method.
Once you've discovered the cause(s) of the disabling, get your subscription back (for least frustration do this without unneeded browsing)
Right click (on each cause found above) the entry and choose analyze. This will give you a smaller result, one which (hopefully) the subscriptions are obvious, right click those entries in the details pane of ccleaner's analysis and choose to add it to the exclude list.
Here's how to find the entry that is removing the ad subscriptions. Starting with the chrome section, right click an entry (e.g. Cache) choose clean Open chrome; if broken take note and continue If not broken continue Close chrome Right click the next entry under chrome heading and continue throughout. If no chrome entries break the adblock you'll have to work each entry in ccleaner in this method. Once you've discovered the cause(s) of the disabling, get your subscription back (for least frustration do this without unneeded browsing) Right click (on each cause found above) the entry and choose analyze. This will give you a smaller result, one which (hopefully) the subscriptions are obvious, right click those entries in the details pane of ccleaner's analysis and choose to add it to the exclude list.
I don't want to completely disable cleaning cache (or something else), I just want new fixed version where everything works like before.
It is a bug and clearly it's there, because I don't have problems anymore since I've made a switch to v5.15.5513
