I play games on Facebook the use flash. I realize Chrome has it's own flash but the object is the same. When the game first opens, I am prompted by flash for how much cache to let the program use. It starts at a default of 10M, but later the game itself asks and sets it to unlimited. I'm fine for weeks, months, whatever till I run crap cleaner on chrome, then this whole process repeats. I haven't have time to find what it is that is cleared, but rather than clearing the cache it uses, it also clears the settings. Not a big bug, more of a "wish it wouldn't" thing.
Maybe you guys know more about what's going on behind the scenes than I do.
Thanks.
Running Windows 8 64bit, Chrome 27.x and the only setting that I'm running is Internet Cache & Cookies.
I don't have Adobe flash installed. I know I was vague with the "chrome has it's own flash". I think it's pepper flash. Anyway it's not Adobe. So I can't do those settings you suggest.
Besides that I've been playing with the analyse feature and seeing what files CC is removing. I tried it in pieces manually trying to eliminate which one was doing it. NOW I can't replicate the issue. I ran CC and chrome keeps working. So I may have found a bug but maybe in the user not the program So for the time being I think this should be dropped. Unless someone sees the same issue then it's worth more time. There are bigger and better things to play with.
If this happens again, another person was trying to clean out the Chrome Flash and made an Include, you could reverse their findings to input an Exclude in CCleaner:
