Have tried suggestions in GOOGLE (signing in to account/unchecking "older than 24 hours" option) and still have to manually clean history manually.
Would appreciate suggestions
Thank you, Codyc
Thank you, Codyc
Do you have your browsers synced?
Is anything browser related running in the background after you close them? (You can often see in Task Manager).
What sort of thing are you meaning by 'history'? Sometimes users confuse the 'history' with the 'session'.
See the second half of this for more about why some things can/will come back straight after you clean them (including of your browser is synced):
Thank you, nukecad.
Have not gotten around to investigating you suggestion. Will do so soon. Had not responded due to a senior moment regarding the question
Cheers
You may be interested in this, another user who had a similar problem with EDGE preloading and running in the background.
I'd given them much the same answer as I gave you here.
