Everytime I run cc cleaner it stops and ask if I want cc to close Chrome (even though it is not running) and I say "yes". Then it comes back asking if I want to force it to shutdown Chrome and I say yes. Then it finishes cleaning. I know after looking at my running process's that Google Chrome is running. Can this be fixed? How would that be done?
You don't need to disable sync and cloud print. Just make sure "background apps" are disabled in the advanced settings. (scroll to the bottom of the Settings page and click "show advanced")
I've tried turning off "Continue running background apps when Google Chrome is closed" and that doesn't kill it on closing. Only turning off cloud printing works for me, removing the startup entry "C:\Program Files (x86)\Google\Chrome\Application\chrome.exe" --type=service in HKCU\Microsoft\Windows\CurrentVersion\Run\0EF39F5CD2F93E2D49A90D9D56ACFA1B90BF26B7._service_run
I hardly ever want to print to home while out and about but would like this facility to be there and for CCleaner to close Chrome fully and smoothly. Is there a way that the feature could be incorporated in a future version? I'm running v4.00.4064 on two laptops; one with 64-bit Win7 (that's where the registry entry came from) and 32-bit Win7, which has a corresponding entry without the "(x86)" bit.
..............................................would like this facility to be there and for CCleaner to close Chrome fully and smoothly. Is there a way that the feature could be incorporated in a future version?......................................
