I am in the process of recovering an external 1.5 Terabyte HDD which was inadvertently quick formatted. Until using Recuva, the drive has not been used at all. After 6 hours it indicates 16% done, capturing 1.5 million files, estimated time left 1 day.
Problem is, Recuva is running on my “main machine” which I really need to put to other use. I have another computer and could restart the process and just let it go “forever” if necessary. Before doing this, though, I have two questions.
#1 – Would stopping the deep scan on machine #1, installing Recuva to machine #2 and restarting the scan using #2 cause any loss of files already scanned (thru machine #1) ?? Or, to put it another way – Does stopping a Recuva deep scan return the drive to its “original condition” ??
#2 – I understand Recuva writes a “working list” of files found as it goes about its business. Could that file be copied from machine #1 to #2 and possibly save some repetition in the new scan ??
Really need to get as many of those files back as I can, but need to use my main machine, too. (#2 doesn’t have the horsepower needed for the work waiting.)
Thanks for any help.
