I need a program to change shortcut icons, thousands of them.
I've got a folder full of about 7,000 shortcuts, and I want to change the icons on all of them! I've already got the .ico bitmap image ready, but I certainly don't want to sit here and do 7000 manual "change icon" operations. Of course, each of these shortcuts is going to have the same .ico file.
There has to be some sort of freeware program out there that will let me do this batch style?
I don't have an answer for you Keatah, but your Operating System may help as any fix may be different depending on what you're running.
EDIT: Just offhand, the nearest I can think of to mass change an icon is TweakUI, which is compatible with Operating Systems from XP to win7, both X86 and X64 ...
System requirements of TweakUI:
OS Windows 7/VISTA/XP/2k/2k3/2k8 x86 x64
Minimum screen resolution 1024x768
CPU: Pentium processor and above
RAM: 128 Mb RAM
HDD: 5 Mb free disk space
Download size: 1.4M
It's free of course, but maybe goes a step too far to what you want.
That will only change the overlay icon on shortcuts, it's the little arrow that shows on them which I turn off.
7000 shortcuts, you and SuperFast should get together at a pub over a pint, and brag about your level of shortcuts and browser tabs.
I've never heard of any program capable of changing them. TweakUI as DennisD mentioned can refresh the icon cache after you've changed them.
Welp.. I found a solution late last night. 1st I opened the file folder containing all the shortcuts. Then I put it in LIST view style. Then I turned on my mouse/keyboard recorder and changed one shortcut manually using the keyboard. Advanced to the next shortcut. Stopped the recorder at that point.
<alt> F R [[opened the properties window]]
<alt> C <ctrl> V <return> [[pasted the path & location of the new icon image file]]
<return> [[closed the properties window]]
<down arrow key> [[advance to the next file]]
I set the recoder to play that back 7000 times, and down the list it went. It changed all the shortcut icons with great dispatch! Much faster than me doing it manually.
Digital elevation models, .DEM files, from various solar system bodies. 7,000 files is nothing. The amount of data being returned from planetary science craft and astronomical observations is astounding. 100's of terrabytes is an appropriate yardstick.
