How do you get this box to quit popping up every time it does a clean? It gets in my way too often and I have to stop what I'm doing and X it out several times per day.
Options..Smart Cleaning.
Untick the boxes.
1 hour ago, hazelnut said:<div class="ipsQuote_contents"> <p> Options..Smart Cleaning. </p> <p> Untick the boxes. </p> </div>
That's the pop-up you get when you close the browser. Are you seeing it at other times?
To expand on Hazelnut's post:
Open CCleaner and go to Options > Smart Cleaning
Under 'Enable Automatic Browser Cleaning' you will see your installed browsers listed, with next to them a drop down section for the cleaning choices.
You can set a different choice for each of your browsers.
The choices are:
- Do not monitor browser.
- Prompt me to clean on closing.
- Automatically clean on closing with notification.
- Automatically clean on closing without notification.
So if you want to clean the browser when you close it but don't want the pop-up then you would select choice #4.
If you don't want to clean a particular browser when you close it then select choice #1
If you don't want it to automatically clean any browser then untick 'Enable Automatic Browser Cleaning'. (or select #1 for all browsers).
If you don't want it to automatically clean anything at all then untick 'Enable Smart Cleaning'.
