Ok guys/gals.
For the past week I've had problems with both my CD drives not auto running. Now the Autorun.inf file is correct I just have run the file stated in there. Now normally you can right-click on your CD Rom and select AutoPlay but this option as disappeared. Now on good OS you can check the CD Rom properties in Device Manager and there is a checkbox for Auto Insert on WinXP there isn't. I did a web search for this problem and people were taking about changing the settings in the registry which I did and that didn't work.
I was searching for info on Windows 7 and I came across this Windows XP link at Microsoft. In there they have a Autoplay Repair Wizard on the second page which you download and run. This has the option to select the drive you want to Auto Insert and it works. Now the funny thing is you have to do a restart before you can select another drive. I have 2 DVD writers D: & E: I use E: the most so I enabled that one and it now works.
If this is in the wrong forum please move it for me.
