ccsetup532 (532.0.6129) not installing in Win10 Pro 1703 (15063.413)
ccsetup532.exe freezes a few seconds after launching. Anyone else experiencing this?
My issue is the installing, it says "Error opening file for writing".
Not seeing that, can you provide more details, such as: antivirus, and anything else we may need to know. Also check to see if ccleaner is running at the time (including monitoring)
Your issue is likely different, ccleaner is still running and that's why it can't open the file. If exiting doesn't fix your issue we ask that you please start your own thread.
upgraded today to v5.32 without issue.
but then, I did the download directly from the Builds page, then did an over-the-top install against the currently installed version.
I had the same problem earlier today and found a pending Windows Update was causing this issue. Once I updated Windows, the install was seemless.
