Running latest version of Windows 10 and Kaspersky. Prior to installing 5.44, all prior versions of ccleaner worked fine. This latest version will run the analyzer and find all files to be deleted, but when I push the Run Cleaner, the program immediately closes without cleaning.
I can run the Regiatry fixer fine.
i’ve uninstalled the product, rebooted my computer a couple of times. Even tried downloading a prior version to see if the problem would correct itself. No luck. Ccleaber just closes without cleaning. Any suggestions?
