CCleanet not working correctly with Android 16
Since update to Android 16, CCleaner is not working correctly
Hi @GGBACK,
Please submit a support request to our team via the Contact Us form on the CCleaner Help Centre.
Once you have done this, please message me back so I can locate this request and ask the team to prioritise your case.
I did submit my support request
Hi @GGBACK,
I have found your support request and asked the team to prioritise the case.
If you have not received a follow up from them within 24 hours, please message me back so I can investigate this further.
@Laurence_CCleaner I’m also having the same issue on my Samsung Galaxy A36 5G. I submitted a ticket.
Using CCleaner Pro v.25.17.0 on a Samsung S23 Ultra running Android 16. CCleaner no longer runs correctly and is very slow. In the Cleaning results there are multiple “System error(device not supported), “Undefined error” and “System error (no events) reported - in total “Failed items” = 11. Some of these are BBC news, Chrome, Firefox, Galaxy Store. YouTube etc.etc. Can this be investigated and fixed if possible, please?
Hi All,
We will soon be releasing an update to CCleaner for Android that will resolve some issues with Android 16.
If you continue to experience issues after updating to V25.21, please message me back so I can investigate this further.
Maybe my post on this subject can help you debug. Check it out
Still not working after the update.
Samsung A56
GGBACK is a user experiencing the same issue. I am not affiliated with CCleaner.
I am a user experiencing the same issue. I am not affiliated with CCLeaner.
I am a user experiencing the same issue. I am not affiliated with CCleaner.
Where is your post on the subject? I cannot find it.
Have not seen any update so far.
It sounds crazy but this worked for me. Start the clean. When an app screen comes up slide up ASAP and do the same for every app until the clean finishes.
