CCleaner won't stay minimized
Installed v2.01.507 a while ago and it seems to work ok, except for a minor problem.
I have CCleaner set up to exit when finished. When I start the cleaning process, I minimize CCleaner.
At some point in the process, CCleaner restores itself to normal visibility, then exits.
All previous versions exited without popping back up on the screen.
Kevin
