CCleaner won't let me add another drive.
I have a ton of hidden files on my secondary HDD that I'm trying to clean up; like, about 400gb worth (not joking). CCleaner lets me analyze the drive and indicates 82.54% is being occupied by "Other Files." Ok, so I should just add the drive via options -> include -> add, correct? Well, when I try that, it tells me "For system safety reasons you cannot select this specific location." So... is CCleaner supposed to be used ONLY on a drive that has an OS? How can I get around this? I really need to remove these files.
i have try it...
on my drive d:
i have create a folder with 4 files of ".jpg" and have set it to hidden and read only.
so it seems, ccleaner could not clean this included folder with this kind of files...
is on your secondary drive installed an os?
