Recently I downloaded the portable version of Waterfox , a Firefox based browser for those who don't know , and am trying to get CCleaner to do the same good job with it which it does cleaning unwanted stuff from my installed Firefox browser.
The problem is that most of the information here and on other forums seems to relate to Waterfox being installed too rather than portable.
I understand you have to add a custom path to the CCleaner.ini but, here's the problem: the portable version of Waterfox, unsurpisingly does not use the same locations as an installed one. However, confusingly it does still create the same Users/xxx/ AppData/Local and Roaming > Waterfox folder described in the guides here for adding a custom CCleaner path to the Waterfox "Profiles" data.
The trouble is that these folders do not contain any "Profiles" data, they remain empty even after a session using Waterfox when I've installed new Add-Ons, changed preferences, edit the about:config and it has picked up plenty of, mostly unwanted, cookies etc. It seems they're not being used, so what they're there for I have no idea.
Looking in the actual WaterfoxPortable folder, which is currently located on a separate C:\drive folder: Portable Programs, there are no "Profiles" folders there either. But in the Data folder there is a "profile" folder which appears to be the meat of the browser ie. it contains all the equivalent C:\Program Files\Mozilla Firefox program folders/files.
The question is: do I set this "Custom Location 1=FIREFOX|C:\Portable Programs\WaterfoxPortable\Data\profile" as the CCleaner custom path or do I need to be more specific? If so what folders/files path or paths should I set?
What I do not what to happen is for CCleaner to wipe the entire "profile" folder and destroy WaterfoxPortable in the process but I do, obviously, want it to recognise the things like the cookies, session, cache, dowload history etc and secure delete them as it does for Firefox.
Advice appreciated.
