Ccleaner wipe drive concern.
I am doing a singe pass zero wipe of my Imac 2tb drive. Started around 1am 02/10/13 and is still going at 10:39am 2/10/2013. Below is the message that it shows and has shown so far.
Detail- I can see the spinning next to it, no progress bar.
Started erase on disk0s2 Macintosh HD
Creating a temporary file
Securely erasing a file
I was just concerned that it is not working or stuck, I also have the trash bieng emptied.
Any help, thanks.
email address removed by moderator to prevent spamming
do you have a HDD or SSD for your drive. The MAC wipe process is just calling the OSX command for drivevwipe
I am having the same issue. CCleaner wipe has been running for almost 24 hours. The following message appears in the box -
Started erase on disk0s2 Untitled
When I try to get out of the program, I get the following message:
CCleaner cannot be closed until the Erase Free Space operation is complete.
This is a MacBook Air with flash storage.
Post 1 - I would expect that wiping a 2 tb disk would take aeons. Post 3 - what are you wiping, SSD? Disk size?
