Hello All - this seems to be a much-discussed issue => Chrome is skipped while cleaning. I am running Version 78.0.3904.97 (Official Build) (64-bit)
under Win10 Home currently. At one point in time in the past I ran into this and I found someone who had a fix for the problem, but it seems it's back now!
I have tried:
Unchecking "Continue running background apps when Google Chrome is closed" - still skips all things Chrome-related.
Running as incognito as suggested in another post - still skips all things Chrome-related. Don't know how to run as "guest", though, so I can't try that suggestion.
Any further ideas to try? Not an expert here, would appreciate anything more you can point me at in order to fix this problem. I hate having to go into Chrome manually and clear things out!
Thanks in advance.
-RJF
