CCLEANER v5.73.8130 (64-bit) NOT SAVING COOKIES
I tried moving several cookies from the left side to the right side but when I re-open Ccleaner they have moved back to the left side??? This has never happened before???
I recently changed my settings in Win-7 to require the Administrator approval before making any changes to my computer, so I opened Ccleaner to 'Run as Administrator' and there are no cookies on the left side to move to the right side???
Has Piriform changed the way to save cookies so that they aren't deleted?
I have submitted the above Support request 3 times during the past month and I receive a reply from 'CCleaner Support
<support@piriform.com>' stating "[Request received] We've received your request. Please check this email for additional information (and
some links that may help you while you wait)", but I never receive any support help???
Do you have pro and have a unexpired license? If yes, are you submitting the support requests under the same email address you used to subscribe?
Hi D2S, this is not something I have heard reported before, although it seems plausible that the Administrator change could have effected things. CCleaner needs these privileges to do most of its cleaning. I would suggest uninstalling and reinstalling CCleaner and seeing if that resolves the issue. You may want to back up your CCleaner settings which are stored in the Registry before you uninstall:
  • Computer\HKEY_CURRENT_USER\SOFTWARE\Piriform\CCleaner
  • Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Piriform\CCleaner
