Starting with Ccleaner v5.17 when opening the programme in Cleaner both Analyze and Run Cleaner buttons are grey. I have to switch to Registry and do a Scan for Issues. Afterwards when changing back to Cleaner both buttons Analyze and Run Cleaner are blue and can be used.
Happens on both Windows 10 Pro 32bit and Windosw 10 Home 64bit since v5.17
Any clue what to do?
Rgds,
Arne
Sounds like it's taking a scan of the applications you have installed for the applications tab. This scan is usually instantaneous, however can be greatly slowed down if the user uses a winapp2.ini file, especially if it's a large ini, such as using the entire community template without editing out the applications you don't have installed.
So my first question in these cases is do you have a winapp2 file? If so, and you remove the file from the ccleaner directory, does the delay go away?
You were absolutely right, Nergal, thank you very much. In my Program Files\Ccleaner I found a winapp2.ini of 826KB, which seems to be the entire community template. The file must have been stored there when I tested [Voldemort]. Using a small winapp2.ini on another PC I was not aware of the performance effects the total template would have on Ccleaner.
After deleting the template Ccleaner performs as before, thank you again
Arne
No problem. We dont really mention the thing you tried here, so I've edited your post accordingly. ![:)]()
