HP Laptop, Running Windows 8.1 and CCleaner v 5.03 and I am unable to start CCleaner and when I try to Uninstall it hangs up part way through the uninstall process ( I let it run for an hour or so). The previous version of CCleaner v? was installed and would not open so I installed v5.03 over top with the same issues. The only way I can make it run is to install it and it asks at the end of the install if you want to the program to open. I let the program open, used to get rid of my history, did a registry cleanup, shut down the computer, restarted and it still does not work.
When you try to open CCleaner again, have you looked in the taskbar near the clock to see if there is a ccleaner icon there?
It may have minimise to taskbar option selected which may be why you cannot see it on the screen.
When you try to uninstall CCleaner look in your taskmanager first to make sure it is not already running, if it is click on it to highlight is and press the end process button.
None of those files belong to ccleaner, where do you download it from
Maybe those are embedded into CCleaner.exe - not that we'd know though. And a mention of them in this PortableApps.com topic from 10 years ago in 2005:
Original was from Cnet, but just reinstalled from piriform, reboot and the same thing. It won't open by double clicking on the icon, but when I check in Task Manager there are three of them listed. I ended process for all three, then right clicked on the desktop icon and selected Open as Admin and it opened? Just tried to uninstall by clicking directly on uninst.exe and the uninstall froze as described in my comments above?
The version you had previously, was it a very old version from years ago? Only ask because that PortableApps.com topic from 2005 shows them registering those .DLL files for some reason.
Those .dll and .ocx files as long as I remember going back to 2004 when I first started using CCleaner have never been installed by it.
The previous version was from 2013.
I don't know. Perhaps try the portable build of CCleaner and unzip it into its own unique folder to see if it works.
Also might help to look at your anti-virus, anti-malware, and firewall logs to see if they're blocking CCleaner.
