CCleaner v3.02.1343 does not clean registry
Hello,
i use the latest build v3.02.1343 and when i remove the found registry problems they re-appear with the next scan.
System: Windows 2000 SP4
Logged in as administrator
Whats causing this?
thankyou
Welcome to the forum :)
What are the items that keep reappearing?
Do you mean all the items reappear?
Hi there,
yes correct.All items re-appear in the list again.For example:
Ungenutzte Datei-Endungen .ipo - ISWI.ProjectFile.1 HKCR\.ipo
Ungenutzte Datei-Endungen OISbmpfile HKCR\OISbmpfile
Ungenutzte Datei-Endungen OISemffile HKCR\OISemffile
Ungenutzte Datei-Endungen OISgiffile HKCR\OISgiffile
Ungenutzte Datei-Endungen OISjpegfile HKCR\OISjpegfile
Ungenutzte Datei-Endungen OISpngfile HKCR\OISpngfile
Ungenutzte Datei-Endungen OIStiffile HKCR\OIStiffile
Ungenutzte Datei-Endungen OISwmffile HKCR\OISwmffile
BR
Mario
I have those OIS references on my system immediately after there's a Microsoft Office security update. They can either be excluded in CCleaner's "Options->Exclude", or ignored, or removed.
That was an example.The list is much longer and contains old installed software entries.They also re-appear after the removing/cleaning process.
BR
