CCleaner v2.35.1219 won't detect Adobe Flash Player.
Not listed under Cleaner > Applications > Multimedia
Flash cookies aren't listed in Options > Cookies
This is the case on both of my boxes, XP and Vista.
I'm using Internet Explorer as my browser.
I can confirm that this is true
I can also confirm that this is due to double detect given in the inbuilt ini
if someone doesn't have flashplayer.xpt in the "%windir%\system32\Macromed\flash\" folder (as I did not) but does have the registry entry HKCR\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000} flash will not show in ccleaner. I confirmed this by making a text file and calling it flashplayer.xpt and placing it in the folder.
Previous detect for flash was only the reg entry
Note this also made winapp2.ini flash entry appear (which also was not appearing until this file was added)
Confirmed on Windows XP
Creating a dummy empty flashplayer.xpt file then Adobe Flash Player is correctly detected,
as said by Nergal above.
Thanks, we are working on a fix.
Some FYI:
Versions 2.33 and 2.34 did not show the flash player. Version 2.34 also had cookie removal problems for me so I went back to 2.33 and, in the mean time, I uninstalled and reinstalled adobe flash. Adobe flash still did not show up.
I installed ccleaner version 2.35 and Adobe flash shows up and all the cookies I've accumulated! I was able to remove all cookies that showed up in 'cookies to be removed'. For now, everything is working perfectly.
XP Home SP3 Opera 6.1
The .xpt file extension is a component or plugin (such as flashplayer.xpt) that adds features and functionality.
Those of us who don't use Firefox, Safari, Opera, and are using CCleaner v2.35.1219 will be affected by it not being in the folder.
The work around is stated above until an official fix in implemented.
I was just prompted to update CCleaner and when I went to remove Flash content, the Flash option wasn't there. I did noticed other options were added, which is nice.
I use the Flash Storage Settings page to remove Flash content, but I also like to run CCleaner after that to remove any other Flash files.
I'm using the latest version of Chrome beta on XP.
Hmm sounds like you have a different issue if you paste "%windir%\system32\Macromed\flash\ into the run box, do you see a flashplayer.xpt?
Note: I have tested this and the detectfile overtakes detect(registry). By this I mean, if I have "%windir%\system32\Macromed\flash\flashplayer.xpt but do NOT have the registry entry HKCR\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000} Flash is still detected by ccleaner
Also for those not willing/unable to make a file in the %windir% add the following to your winapp2.ini
[*Adobe Flash Player Temporary Entry]ID=2055
LangSecRef=3023
Detect=HKCR\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}
Default=True
SpecialKey1=N_FLASH_COOKIES
Note: I have tested this and the detectfile overtakes detect(registry). By this I mean, if I have "%windir%\system32\Macromed\flash\flashplayer.xpt but do NOT have the registry entry HKCR\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000} Flash is still detected by ccleaner.
There is no flashplayer.xpt file, but before the latest update, CCleaner was able to display Chrome's integrated Flash in its settings.
ID=2055
LangSecRef=3023
Default=True
I am using IE8 on XP SP3.
Found that -
(1) dummy flashplayer.xpt file added an entry but did not result in detection
(2) adding above to winapp2.ini added an entry did not result in detection
(3) adding copy section below for Adobe Flash from embedded ini to winapp2.ini worked
[Adobe Flash Player]
LangSecRef=3023
Default=True
FileKey1=%appdata%\Macromedia\Flash Player|*.*|RECURSE
Found that -
do you have windows hiding the extentions for known files if so you probably inavertantly made flashplayer.xpt.txt
yup after some further investingation Chrome has flash built in and it runs from gcswf32.dll
can you do me a favor (since you have an installed chrome as opposed to my portable build) can you put chrome://plugins/ into the address bar and copy paste
Shockwave Flash - Version: 10,1,53,64 Description: Shockwave Flash 10.1 r53 Location: M:\GoogleChromePortable\App\Chrome-bin\5.0.375.125\gcswf32.dll
so the devs can work with that too
[rant] HA! Yet another reason for me not to like Chrome. IMHO built flash is bad idea. Note that it is at least one version old, and that you pretty much have to wait for a chrome update or jump through hoops to get the latest version. [/rant]
note to all: MR T already stated they are working on a fix, so this should not be a problem for too long
No!
save the file as "flashplayer.xpt" but under "all files" not "text file"
This is what I have done. See my last post.
I think you should check again, because DetectFiles override Detect Registry, and by that logic the entry should be there. (Make sure you've saved it to the correct folder too, which is %windir%\system32\Macromed\flash\ )
Shockwave Flash - Version: 10,1,53,64 Description: Shockwave Flash 10.1 r53 Location: M:\GoogleChromePortable\App\Chrome-bin\5.0.375.125\gcswf32.dllso the devs can work with that too
Here's the requested info.
Flash - Version: 10.1.82.76
Shockwave Flash 10.1 r82
Description: Shockwave Flash 10.1 r82
Version: 10,1,82,76
Priority: 2
Location: C:\Documents and Settings\[username removed]\Local Settings\Application Data\Google\Chrome\Application\6.0.472.51\gcswf32.dll
Regarding built-in Flash in Chrome, I actually like it :-) I mean, there was that time back when a new version of Flash 10.1 RC was out and Chrome was still using a version number lower, but that's been about it. I do hate though that I have to wait for Google to update Chrome and Flash, but if I install Flash and disable the integrated version in Chrome.
add windows 7 to the mixed new version updated adobe everything but flash player is not listed in apps?
Well, the first time I tried it, it didn't work, now I just added a dummy "flashplayer.xpt" file in the Flash folder and Flash now appears in CCleaner's Multimedia menu.
I don't know if I have HKCR\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000} 'cause I don't know where in the Registry to find it, but creating said dummy file does make CCleaner detect Flash.
Thanks for the tip Nergal.
I'll wait for the update to CCleaner before removing that file.
HKEY_CLASSES_ROOT = HKCR
So that would be the CLSID subfolder of HKEY_CLASSES_ROOT
An easy way to instantly browse to registry key locations via 'Start->Run' is with Microsoft Sysinternals Regjump.
