CCleaner v2.23 Rebuild
Hi all,
Due to a couple of issues found by our forum members and the new Opera 10 release, we've published a new build of CCleaner v2.23 :)
v2.23.999
- Improved Opera 10 support for final release.
- Fixed the "No Disk" exception error.
- Fixed %ProgramFiles% bug in 64-bit Registry scanning.
Hope you like it!
MrG
I have to say that's a pretty speedy fix.
Nice one.
Yes the Error No Disk has now been fixed, thanks MrG. ;)
Excellent work , MrG.
Thanks a lot MrG!
I'm afraid it back MrG.
I've just done a Registry check and its asking for the disk to be inserted again. This time its showng up with ActiveX and Class Issues ticked as before and MUI Cache ticked. ;)
Hi all,
v2.23.999
Hope you like it!
MrG
I have just downloaded the new version of CCCleaner and cleaned my system, but every time I clean the drive my Adobe Reader version 9 becomes corrupt and I have to repair the Adobe installation before I can download any pdf files correctly. Am I missing something or can someone help me overcome this annoying problem?
Chris
Welcome to Pirifrom Chris.
Well I use Adobe 9.1 and it still works as it should do after a clean and my Adobe 9.0 is ticked in Applications. Adobe Reader 9.1 ;)
Adobe PhotoShop CS3 is still ticked but I uninstalled that a couple of weeks ago. Windows Live Messenger is ticked and I've never installed it and don't use it. I use MSN Messenger whether that classes as the same which is a pain in backside on XP.
