CCleaner v.5.73 does not clean all Chrome cookies. How do I revert?
HI there,
Till yesterday I had been using CCleaner v. 5.53 or so. Now once I installed the latest version I've noticed new CCleaner does not clean all the session data, so I stay logged into forums even once the cleaning is done. Is there anybody else to confirm this observation?
Where do I find the archive of previous versions of CCleaner?
System information: Windows 10 Home 1909 64-bit, Chrome 64-bit the latest version
Thanks.
Try this first with Chrome, the instructions are still valid in 2020:
https://community.ccleaner.com/topic/40285-ccleaner-not-deleting-google-chrome-history-fix/
Old versions of CCleaner are available on FileHippo (look on the right side to download an old version), but do note old versions will eventually be incompatible with Windows 10 which will block their usage:
https://filehippo.com/download_ccleaner/
38 minutes ago, Andavari said:
Thanks, Andavari. FileHippo's archive is somewhat corrupt or something because whatever file version I click on it always returns the same result link https://dlccleaner.filehippo.com/ccsetup563_pro_fh.exe
I think I've found the solution to the problem. It had nothing to do with Chrome background service (which was turned off in my case). I tried to install a new version of CCleaner while CCleaner itself was running in the background from the tray area. Once I exited CCleaner and cleaned Chrome's data for the past 24 hours, the problem successfully resolved.
