Hi I just updated Ccleaner free v5.54.7088. It has downloaded and installed but there is no content in the right side panel. I have re-started my laptop and also installed a second time. Non of this works. I am using an Acer laptop running Windows 10. My husband has same problem running an HP laptop Windows 10. Please see the screenshot encl.
It looks right to me, what exactly did you expect in that pane? It is where the results will be when you analyize/clean.
Thank you Nergal. I could not see the Analyze and Run Cleaner buttons that are usually displayed when the screen is minimised. It usually opens up after updating as a minimised screen. However it opened up Maximised to such an extent that the buttons were way off the screen, even when I click on minimise it fills the screen but that's OK as I can now see the buttons on the right hand side.
The screen size may be because of this mentioned here
Thank you Hazelnut
