CCleaner tweaks?
CCleaner is mainly used for ppl trying to get their comp faster...Well i think it should have more "tweaks" and optimizations...Like maybe intregrate defraggler in CCleaner...and have a 1click speed up which runs diskeeper/reg cleaner/defraggler or something like that...
I disagree! I think it's mainly used to clear out privacy data.
If someone wants to use something to make comp faster, they should use Auslogics Boostspeed.
http://www.auslogics.com/en/software/boost-speed
Respectfully, I see you both being correct.
When I run CCleaner and clear up a lot of programs that are running automatically. When finished, I get a much better responding computer; hence a much faster computing experience.
I run CCleaner to clean up my surfing tracks. personal information and temp files. This again helps speed up my computer. I know that CCleaner doesn't brag about their registry cleaning capabilities, but I feel it does an excellent job too. Could it do better? Sure... and I think that is what Truthseeker is saying when he recommends Auslogics Boostspeed. So, both of you are right on track.
I would like to know more about Auslogics Boostspeed. This is the first I have read of this product.
Keep up the posting!
-Riggo
I thought it might be a good idea to post a response to the original thought process. Coldplayer was discussing tweaks and add ons. I really have enjoyed the defrag tool (defraggler) from Piriform. It is quick and accurate. I think it would be a great addition to the product. I started another thread on making CCleaner more of an Enterprise solution. This would be a great add on. To have CCleaner run all the clean up processes and a quick defrag WITHOUT user intervention would be a God send!
Just my 2 cents worth...
-Riggo
-Riggo
Auslogics is very well known for their defrag program. I use it in vista and it's great.
Highly recommend Auslogics defrag and Boostspeed.
ive used auslogics..its not that special...i prefer tune up 08 atm..but if CCleaner were improved with tweaks and stuff id certainly favour it ALOT more..plus CCleaner is free :D
....AS It Should Be!
:P
