CCleaner System tray crash
Hello,
I'm using the latest version of CCleaner Pro, I've noticed that CCleaner keep crashing from time to time.
Basically I've set CCleaner to auto clear browser with notification once i close it.
But sometimes i close the browser and didn't receive a notification and even find the browser history remain the same without cleaning.
Once i check the system tray and hover by mouse over CCLEANER icon, i noticed it's automatically disappear ! so i believe there's a crash done from time to time.
please pay attention to this issue!
@Andres Lara: You might need to provide a bit more information about your system configuration for someone to help you, such as:
  • What version number of CCleaner are you using? (If the issue was CCleaner-specific then it would have impacted other users, and likely have been solved in one of the releases since April)
  • What version of Windows are you using? If Windows 10, which update version (1809, 1904, 20H2, etc)
  • What AV and firewall are you using? Are they up to date? Have you set them to block any CCleaner services?
