CCleaner suddenly not launch on start up
Once I selected Quit CCleaner from the icon on the menu bar, then it never show up on the menu bar again???
Quitting from the icon will close the CCleaner background tasks and so will remove the icon - but only for the current session.
The tasks will restart the next time that you reboot your computer, or the next time that you open CCleaner, and the icon will come back.
You will get a CCleaner icon in your system tray if you have Automatic Updating selected.
If you don't want to see a CCleaner icon in the system tray then you have to have and Automatic Updating turned off.
10 hours ago, nukecad said:
		Windows will remove the icon
this is about Mac
Thanks @Nergal
I'd just posted a cut/paste about the system tray icon without checking, I've now removed references to Windows options.
The CCleaner will never launch at startup since then.
I have restarted my Mac several times and still wouldn't launch at start up, now I lost the automatically cleanup when my browser quit???
