Hi,
Using Win XP Pro x64.
The registry cleaner reports-
Missing Shared Dll:
C:\WINDOWS\system32\TosBtCi.dll
However this file is present in C:\WINDOWS\system32.
I suspect that the registry cleaner is actually looking for TosBtCi.dll in C:\WINDOWS\SysWOW64 as the OS (WinXp Pro x64) is redirecting queries on the C:\WINDOWS\system32 path to C:\WINDOWS\SysWOW64 for non x64 native applications.
I really can't recommend that the registry cleaner be used until it is 100% compatible with x64 systems.
Regards,
niche99
