I haven't gotten any response from SPEED or SECURITY when applying for Health cleaning.
Are you using CCleaner Free or Pro version?
You need Pro for those two to work, and if there is nothing that needs changing or updating then they will simply say zero found.
21 hours ago, nukecad said:<div class="ipsQuote_contents"> <p> Are you using CCleaner Free or Pro version? </p> <p> You need Pro for those two to work, and if there is nothing that needs changing or updating then they will simply say zero found. </p> </div>
I am using Pro Version V5.66.7716 64 bit and, also Windows 7 Home Version. I noticed this problem when first using Ccleaner, but thought it would work it self out , but never did.
Any suggestions would be appreciated.
I'm not sure what suggestion you are asking for, from what you have described so far nothing seems to be wrong.
SPEED checks your Windows startup to see if it's loading anything at startup that is not needed, which would slow down your computers boot time.
If there is nothing doing that and slowing down your boot time then SPEED will show zero found.
SECURITY checks if (certain) apps that you have installed have a later version available.
If you do not have those apps, or if there are no updates available, then that will also show zero found.
If something has changed with the startup, or if there is an app that needs updating then they will say so, and will make the change/update when you click 'Make it Better'.
Those 2 Health Check areas showing zero is not anything wrong, in fact it's quite the opposite. - It's showing that those two areas are fine.
Those areas will <u>always</u> show zero unless Health Check finds something that needs reviewing or updating.
If you mean that yours are showing something else then please describe what you are seeing, or post a screenshot like that one.
PS.
If you want to double check just what those 2 Health Check areas are looking at then click on 'Tools', and then:
Startup - Will show you what Health Check SPEED looks at.
Software Updater>Up-to-date Programmes - Will show you which programmes Health Check SECURITY is looking at on your machine.
