Hi,
Just to say the latest update on my window 10 is very slow, never been this slow before, we are talking about a minute sometimes a little longer, just seems like ages.
Anyone else have this problem
Thx Len
Hi,
Thx Len
Could you elaborate a bit?
Is CC slow to launch, slow to analyze/clean, or something else?
If it's slow to analyze/clean then it shhold be noticable what it is cleaning when it's taking the time.
(Usually its Internet Explorer).
Just to add to that:
In the past I found that analyze/clean of Internet Explorer was taking a long time.
As I hardly ever use Edge or Internet Explorer I just told CCleaner to stop looking at them.
I have everything unticked for Edge and Internet Explorer - except for 'Temporary Internet Files' because other Microsoft applications use that as well.
(There is always one cookie in Internet Explorer cookies as well, but I just ignore that because it just come back if you clean it).
If you want to double check after a week or so then you can right click on each of the ones you have turned off and anaylze to see if there is anything there.
and do you have winapp2.ini or any other enhancements that could slow it down?
