CCleaner Silent DELETE ?
Using command line parameters found on this page:
https://www.piriform.com/docs/ccleaner/advanced-usage/command-line-parameters
I've created a batch file with this command: CCleaner.exe /DELETE "C:\test.txt" /METHOD 1
and after running bat file it requires a YES button confirmation to delete the file.
I have tried adding /AUTO ("CCleaner.exe /AUTO /DELETE "C:\test.txt" /METHOD 1")
And it didn't delete file
Is there a way to remove confirmation and make it a silent operation ?
