CCleaner repeatedly reports "invalid default icon" for Zone Alarm upd client.
Each time I "fix selected issue" the fault is again displayed the next time I check for issues. I have not gone so far as to test if a reboot is required to re-establish this condition but suspect it is.
My question is, has anyone else found a work around for this problem? It does not appear to have any effect on how either ZA or CC behaves but leaves me wondering what's up.
I suspect some setting in Zone Alarm I am not yet familiar with is creating the icon. Why it is invalid beats me.
Have you tried running CCleaner more than once? Some issues require more than one scan and fix. Also Zone Alarm may just be recreating the key regardless of how many times you remove it. If that is the case the ultimate fix would be an 'exclude' option in CCleaners issues scanner but this doesn't currently exist.
Thank you for your ideas JDPower;
It seems as if Zone Alarm indeed is recreating the key. I am presently trying to register at the ZA forum to see if any help is forthcoming from their readers.
If I was sure how to do it I'd try adjusting the key in the registry. But not at this time......;-)
If I find an answer I'll repost here with a conclusion.
