CCleaner Removing Java after every scan
Not sure if this is the right forum to post, but anyhow, after each scan, it removes java. I have to go back n reinstall java everytime, even so it says its already installed. This started to happen after a few updates. Not sure how to prevent it. Anyone know??
Btw, I tried a search in the forums, but havn't found the answer.
You could always try unticking Adobe flash player in CCleaner applications list.
not sure if java is linked to flash player, but I'll try it.
That and maybe untick Sun Java too, it's listed in:
Large Cleaner button, Applications, Internet, Sun Java.
