CCleaner Removes Flash security settings?
I'm posting this for the security minded folks. I've been using CCleaner for a few months. I'm using version 1.19.105 and noticed this problem with the previous version as well. So far the program performs well in most instances. I have noticed lately though, since setting Macromedia's Flash security settings, that CCleaner flags the .sol files used to store the settings. I can't do a cleanup without resetting these settings. The Macromedia files are by default located at:
C:\Documents and Settings\Current User\Application Data\Macromedia\Flashplayer\macromedia.com\support\flashplayer\sys\#macromedia.com\settings.sol
Has anybody else noticed this or know how to stop the removal? And no, I don't want to disable Flash, I know how to do that.
Some fixes/settings to avoid this to some degree have been posted in this thread: http://www.dslreports.com/forum/remark,13344806
However, this still doesn't help anybody using default settings in CCleaner. Without setting up for this, all security settings in Macromedia Flash will be deleted.
