After running Ccleaner, the volume control icon in the task bar was missing. I checked the audio option in the control panel and the option to show the icon in the taskbar has a checkmark, This is the first time this happend. I have 4 other computers running Windows XP and never had this problem.
I must say I have never had this happen to me.
Did you try rebooting or unticking and then retickking the option again?
May just have been one of those weird coincidences.
Right click the sidetray near the clock and choose Customize Notification Icons and from there you can choose whether to hide or show notification icons. You can choose to hide or show the tray icons from there and click OK.
Open CCleaner and uncheck the"Tray Notifications Cache" checkbox for cleaning. Chances are that you got this checked and that has cleared the settings on how icons in the sidetray are displayed.
