CCleaner Reg Cleaner
I noticed two versions ago, that the reg cleaner seems to never stop. i have the latest version, It used to say %100 and stooped with the final report which we could check, but no longer. I've left it run for quite a long time, twice what used to be normal. Is this a bug or did I miss something somewhere in the news. Please Help. I thank you for the interest.
Can you give a bit more info such as what operating system you have and any other info you think might have a bearing on the issue.
Are you able to untick all options on the left and re-tick them one by one to see if one of the items is the cause?
I am running Win7 Home Premium, x64, Intel I7-860, Quad core, 2.8. I am able to tick and re-tick but I have not tried it. It is set to all the standard settings, as safe as possible for me. I will try as you suggest
