CCleaner recommended to help with unrooting Android
PLEASE HELP!!!!! Im currently using an Android that was loaned to me by a friend after my iphone was stolen. I'm getting used to it for the most part, but the biggest problem that I'm having right now is that I can't use tap to pay because the phone is jailbroken & rooted. In one of my searches CCleaner was recommended for helping me with reversing this so that I can use the tap to pay feature.
I would appreciate any help with this, whether it's advice with this app, another app, or something else altogether.
Thanks!!!
No ccleaner cannot help unroot. I suggest the forum for your device on xda https://forum.xda-developers.com/ .
It should be easy for them to walk you through unrooting. Really a factory reset is probably all you need.
Thanks so much!!!!
What do I do if I don't see my phone listed? It's a motorola one 5G ace, which I'm sure is a bottom of the barrel phone to begin with.
I was given an iphone,, but I have to get into it, it was their dads & he passed away, but no one knows his passcode to get into the phone or his icloud password....it's always something, but I'm just grateful to have something to attempt to use.
9 hours ago, whiskeychick504 said:
https://forum.xda-developers.com/c/moto-g-5g-motorola-one-5g-ace.11863/
https://www.androidauthority.com/how-to-unroot-android-phone-tablet-652905/
