CCleaner Professional short cut problem
I am running CCleaner Professional on Windows 10 and just downloaded an update. When I click on the shortcut on my desktop, I get the message that this short cut doesn't work. How can I get the new shortcut?
Same problem here. At this moment the shortcut and the executable are deleted.
Regards,
Guido
Windows update sometimes grabs and moves ccleaner to the windows.old folder. Try to reinstall ccleaner, this will usually fix this issue. Also be sure your antivirus has not grabbed it as that could be a cause of this problem too.
Thanks, Nergal. I was able to reinstall the program and the working shortcut appeared on my desktop.
