CCleaner Pro stopped working. Shows text "The testing period for CCleaner Alpha has ended." But I have not selected any Alpha testing
This looks more like an issue with the update mechanism than an actual licensing problem. The replies from CCleaner staff suggest that version 7.3 was an older pre-release build and that installing the latest stable version (v7.13) resolves the expired Alpha testing message. However, what concerns me is that some users had automatic updates enabled and still weren’t notified that a newer version was available. If the software itself reports that it is up to date, users have little reason to suspect they are running an outdated test build. I would recommend downloading the latest installer directly from the official CCleaner builds page, but CCleaner should also investigate why automatic updates failed and clarify whether the reported problems with Windows shortcuts and application access are related to this incident.
Hi All,
To help us understand why this CCleaner was not updating and why, when it was manually checked, you were told you were on the latest version, please generate support tool logs using the instructions below:
Share that File ID with me so I can review the logs and investigate further.
From my reading of the situation
I do not think that anyone getting this message actually had a test build at all.
To me it looks more like an old message that is being shown to some users in error
What I find interesting is that it is now a full year since CCleaner 7 was fully released, and it is CCleaner policy to automatically force update versions that haven’t been updated for a year.
This month is the first time that could have happened for CCleaner 7.
So like I say I think this message is an old one from a year ago that should have been removed in favour of one saying something like:
“Your CCleaner 7 version was over a year old, for your security we have updated it to the latest version”
But it seems that nobody got around to making that change to the message.
PS. It would not be the first time that we have seen an old, incorrect, message being displayed in CCleaner. The development process does appear to be somewhat slack in that area.
Same problem—maybe a solution for others, too.
I had exactly the same Alpha problem. I purchased CCleaner Pro Plus on November 4 from the official website. I received a confirmation email with the license key and download link.
I clicked the link and was taken to the page where you can start the download via an unsecured connection (!!!). I started the download and received the file CCleanerBundle-639-Setup.exe.
I installed the program and entered my license key. Everything worked fine so far, and I received a message stating that I now had the latest version of CCleaner Pro Plus, 6.39.11548. This naturally surprised me a bit, since the free version of CCleaner is already at version 7. I then ran several scans and cleanups. Afterward, I worked in other programs. At some point during that time, a window popped up asking if I wanted to allow CCleaner to make changes to the system. I agreed.
When I tried to open CCleaner again the next day, my shortcut to CCleaner Pro Plus had been replaced by a CCleaner 7 shortcut. After clicking on that shortcut, I ended up on the alpha page.
I then thought that the exe file I’d downloaded might be corrupted, so I downloaded it again using the link in the order confirmation email and installed it. At some point, the message about the system change appeared there as well. And after confirming, the shortcut was replaced again.
I then thought that the exe file I’d downloaded might be corrupted, so I downloaded it again using the link in the order confirmation email and installed it. At some point, the message about the system change popped up again. And after confirming, the shortcut was replaced once more withthe one that takes you to the Alpha page.
I then searched the internet, but even after an extensive search, I couldn’t find anything that would have helped. Then I came across this forum, but there’s no solution here either.
At some point, I figured that my Pro Plus version must be so outdated that the system recognizes it and triggers the automatic update, which then leads to the dead Alpha page.
So I reinstalled the program and immediately disabled automatic updates. Then a link for manual updates appeared in the lower right corner. I clicked it and was shown that a new 7.x version was available. Of course, I wanted that one, so I initiated the update. After installation, however, I was still only at version 6.41. So I clicked the manual update again and ended up with another 6.x version. I went through the same process once more, and then I had version 7.13.1591.0.
Now, of course, I’m wondering:
1. Why, in November 2026, do I have to download an ancient version of CCleaner via an insecure connection—one that, through the automatic update feature, leads to an equally ancient CCleaner 7 alpha page that you can only close, and that’s it?
2. Why can’t you download the latest CCleaner Pro Plus version from the official site? Other software providers let you do that.
3. Will I get my next license renewal for free in return for my hours of research and for pointing out the solution described above?
