Ccleaner Pro 6 start niet meer op (en zoals eerder vermeld werkt versie 7 helemaal niet).
In taakbeheer zijn er nochtans actieve processen..
Hi @Mossike,
Vertaald met machinevertaling
Neem contact op met ons supportteam via de contactpagina in ons Helpcentrum met hetzelfde e-mailadres dat u heeft gebruikt om uw aankoop te doen. Nadat u op Verzenden hebt geklikt, klikt u op de knop Chat starten om de details aan een medewerker te geven, zodat we dit verder kunnen onderzoeken.
Hi Laurence,
I managed to reinstall it after rebooting. It works again..
But I am not keen in upgrading to version 7 because there seems to be a lot of problems with it..
Your advice ?
Thanks.
Mario.
Glad to hear you were able to resolve your issue.
Are you experiencing any specific issues with CCleaner 7?
Indeed, upgrading to version 7 doesn’t even start installing, however in task manager there’d a process in the background
May i ask what Operating System you are using?
Windows 11 Home 24H2 build 26120.1350
Is there a solution in the making for version 7 ?
Thanks for these details @Mossike I have sent you a DM on this issue.
Ok, I’ve tried that, but see my comment in my e-mail sent to you
Hi,
I downloaded it and try to install but it says webview already installed.
Best regards,
Mario Mewis.
No solutions for a working version 7 yet ?
Can anybody please tell me if version 7 is up and running?
Also : version 6.3 doesn’t startup anymore.
I have to uninstall it, reboot my pc, reinstall and activate : then it works untill you go out of the program, then it doesn’t start up again !!
Annoying because I paid for it !!
Since a while updating to version 7 doesn’t work : nothing happens.
Also version 6.3 which I run now, doesn’t start up anymore : I always need
to uninstall the program, reboot the pc, reinstall and reactivate.
Quite annoying !
Is there an urgent solution ?
If not, I would like to get my money back.
Thank you.
Okay I am going to cancel my subscription and ask for a refund because via chat they don’t answer.. No good service..
