CCleaner Pro Renewal
Hi
Windows 10 Version
My CC Pro suscription expires the end of Sept 2024 on my W10 device
IF I resubscribe before the end date in Sept '24 on my present w10 device, and purchase an replacement PC W11 the following week/month etc, which I may do if the price is right, am I able to transfer whats left on my Yearly Subscription from my old W10 to my new W11 PC
Thanks in antisipation
If your answer is NO !! Then thats unfair !! And I will cease using CC at the end of my present subscription ??
Tim
That's not a problem at all, in fact it's very easy to do.
Simply install CCleaner Free on the new machine and use your existing licence key to register/activate it as Pro.
If your existing licence is only for 1 device, or if you are already using all the devices that your licence covers, then you should uninstall Pro from the old machine. (You can then install CCleaner Free on it).
The installer for whatever is the latest version can always be found here: https://www.ccleaner.com/ccleaner/builds
