CCLEANER Pro: Auto-update to 554 fails
Download starts and finished.
Then extraction starts and after approx. 30% the error message is shown "Error opening file for writing:" "CCleaner64.exe"
Manual update does not work either.
For previous updates, the auto-updater worked fine.
Does anyone have any idea?
Thanks,
Martin
See if anything here helps
https://forum.piriform.com/topic/5739-solution-when-ccleaner-wont-install-or-download-windows/
Dear hazelnut,
following the instructions in Andavari's post solved the issue.
Thanks a lot!
