cCleaner print setup reset settings on IE 6
I use ccleaner (with winapp2) with the option to start with windows, I would like to know which option I have to uncheck it to not reset the print settings page, why do I configure Internet Explorer to not print with header or footer, and when ccleaner clean, the settings revert to the default printing again with header and footer.
the keys are in regedit ..
[HKEY_CURRENT_USER \ Software \ Microsoft \ Internet Explorer \ PageSetup]
"header" = ""
"footer" = ""
"margin_bottom" = "0.03937"
"margin_left" = "0.31496"
"margin_right" = "0.31496"
"margin_top" = "0.25559"
[HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Internet Explorer \ PageSetup]
"header" = ""
"footer" = ""
thank you very much
