CCleaner on XP Pro SP2 x64
Hi,
CCleaner is not fully compatible with x64 systems. Proof, try to add a folder from C:\Windows\System32 to be included in CCleaners folders to clean.
You will always be redirected to SysWOW64 folder instead as CCleaner is a 32-bit program.
This makes me wonder if the registry cleaner suffers from the same problem.
Regards,
niche99
Thanks, we'll look into this
MrT
