Although I haven't tried it, if you copy all the files from the install folder onto the pen drive, then write a batch file to register all the DLLs/OCX files - run the app - then unregister them. This should work.
You can register with "regsvr32 cchelper.ocx"
and unregister with "regsvr32 /u cchelper.ocx"
I was wondering how to be able to travel with CCleaner on my pen drive between many customers sites, and you give me a direction to work.
I have test your solution, and unfortunately, it is not complete.
I think someone could do better than me, but here is what i did to be able to run CCleaner from different location that C:\program files\CCleaner.
For my tests, I rename CCleaner folder (with CCleaner2 and CCleaner3) that does exactly the same that when you try to launch from a pen drive, with no needed registered files. I have created a batch file that registered all the OCX and DLL files (I made a registry search and discover than both DLL and OCX were registered), launch the program, and unregistered the files.
here the script:
@ECHO OFF
Echo Registering Components
regsvr32 /s CCHelper.ocx
regsvr32 /s ccleaner.dll
regsvr32 /s CCListBar.ocx
regsvr32 /s CCListView.ocx
regsvr32 /s CCSubTimer.dll
regsvr32 /s CCSystem.dll
regsvr32 /s CCTab.ocx
regsvr32 /s CCTreeView.ocx
CALL ccleaner.exe
pause
Echo Un-Registering Components
regsvr32 /s /u CCHelper.ocx
regsvr32 /s /u ccleaner.dll
regsvr32 /s /u CCListBar.ocx
regsvr32 /s /u CCListView.ocx
regsvr32 /s /u CCSubTimer.dll
regsvr32 /s /u CCSystem.dll
regsvr32 /s /u CCTab.ocx
regsvr32 /s /u CCTreeView.ocx
pause
It's a very basic script, so feel free to upgrade the code. i did this very quickly to provide an answer.
One Note: If you want to keep your settings (delete saved password, and other stuff) be careful to backup HKCU\Software\VB and VBA Program Settings\CCleaner key, and do a regedit /s "yourregnamedfile.reg" before launching CCleaner.exe
Hope this help
Regards
